Walbro 255
Old Jul 23, 2010 | 06:55 PM
  #21
Vi3tBoy's Avatar
Looks good.
350 is weird.
I'm at 400 at 13psi on a garrett t3-t4e
Old Jul 23, 2010 | 07:39 PM
  #22
Suzuka_Joe's Avatar
my 5857 ball bearing is at 422 on 13psi......... mase ftw
350hp @18psi seems off
Old Jul 23, 2010 | 09:51 PM
  #23
s2000Junky's Avatar
Motor has low comp on a cylinder or two maybe? Shit I'm making 360 at 9psi with a Comptech. Something definitely not right with 350 at 18psi.. I don't care what dyno it was done on. With a good tune he should be making that with half the boost
Old Jul 24, 2010 | 03:57 AM
  #24
JuicedS2K's Avatar
well I have 3mm hg, clutch was not slipping I don't think. Can a log manifold really be designed that bad? I'm gonna run a compression test and go from there.
Old Jul 24, 2010 | 04:45 AM
  #25
Revenge's Avatar
Maybe he should swap out for a pfab manidold, looks like it would fit around the same spot.
Old Jul 24, 2010 | 08:15 AM
  #26
Irishflame27's Avatar
Originally Posted by Irishflame27,Jul 23 2010, 02:19 PM
manifold design?
DING DING DING!! LOL
Old Jul 24, 2010 | 08:57 AM
  #27
StocS2k's Avatar
Don't do the Pfab Log that is a pain in the ass tight Fit 1.5' clearance just finished my install yesterday quick spool tho!!
Here's my Build
Old Jul 24, 2010 | 08:58 AM
  #28
camuman's Avatar
call the place that made the mani and tell them to redesign that junk!
Old Jul 24, 2010 | 11:39 AM
  #29
spectacle's Avatar
IIRC this kit was bought used from a local shop here in Tampa. I know the builder of the manifold and he doesn't fab his parts with power in mind, more geared toward simplicity and reliability. I'm not surprised his setup doesn't make the numbers it's 'supposed' to.
But I caution everyone not to get so caught up in the final numbers and feel like the car doesn't perform. Alot of you seem to forget that 350whp is still good power regardless of the psi. Oh, I have personally seen that turbo on an "efficient" manifold and world renowned tuner make just under 400whp @ 20 psi! Until you see dyno charts with psi overlay, don't believe everything you hear or see
Old Jul 24, 2010 | 12:14 PM
  #30
teamvalorracing's Avatar
what does the manifold look like?
who made it?
