walbro 400lph, not plug and play
What fpr u running? Stock? Maybe that's the problem. Fuel pressure dropped something fierce up top
18 psi shouldnt be a problem for a single pump. Clamps or lines possibly inflating. Maybe voltage dropping at pump in boost?
. 18 psi shouldnt be a problem for a single pump. Clamps or lines possibly inflating. Maybe voltage dropping at pump in boost?
What fpr u running? Stock or aftermarket? Maybe that's the problem and that part is broken . Maybe clog or kink on the line?
For the hell of it I flow tested my injectors tonight...i know bad flowing injectors would not cause a pressure drop, but it was worth testing out.
Here were the results...pretty good static flow variance. Better than most aftermarket injectors I have tested.
