walbro 400lph, not plug and play
Old Jan 10, 2013 | 08:53 AM
  #81
spectacle's Avatar
Originally Posted by Redline S2K
I wonder if the pain is worth using this pump.
I got the pump in without modifying the hanger and the wiring harness I got with the pump was plug and play. What I was referring to was the actual install itself. I had a ton of trouble getting the fuel lines off, ended up having to use a pair of pliers.
I'll post pics and some details when I get a chance. With the stock regulator and lines my base fuel pressure went up to 55psi vs the stock 44psi with the Walbro 255.
Old Jan 10, 2013 | 09:22 AM
  #82
Redline S2K's Avatar
How much would it go up using just a 340 pump? Thats a good increase in pressure with the stock FPR. When I'm home I'll have to find it, but I read on either a sellers website or another forum that this pump was overkill for pump gas. But people use dual 255 and 340's on pump so I don't see that being true.
Old Jan 10, 2013 | 09:41 AM
  #83
camuman's Avatar
Total overkill for pump piss. But needed for e85 or race gas in the 600 plus range.
Old Jan 10, 2013 | 03:42 PM
  #84
soulicious's Avatar
About the fuel pressure with a 340...I observed a base fuel pressure of 58psi with the stock FPR. THis was with the pump hardwired and using an AEM pressure sensor.
Old Jan 14, 2013 | 08:07 AM
  #85
spectacle's Avatar
Here is an updated thread for future reference https://www.s2ki.com/s2000/topic/999...-pump-install/
equ117
Mar 15, 2019 01:03 PM
Phillie
Jan 15, 2011 08:11 PM
Spec_Ops2087
Jun 11, 2010 09:23 PM
ArinX
Nov 14, 2008 10:51 PM
