Waste gate question?
Old Mar 30, 2012 | 09:39 AM
RedLineS2k10's Avatar
Default Waste gate question?
Noticed the bottom bolt on trial 38mm wasn't there when pulling motor apart...can and will this cause issues?
Sent from my DROIDX using Tapatalk
Old Mar 30, 2012 | 09:46 AM
passmans2kny's Avatar
are u running off just wastegate spring? if so i believe thats supposed to be open
Old Mar 30, 2012 | 09:50 AM
o'malley_808's Avatar
I'd be calling that the top bolt. If your running off the spring you only need a vacuum line connected to the side port.
Old Mar 30, 2012 | 09:51 AM
s2knoob89's Avatar
+1 If not your EBC should be connected to that port.
Old Mar 30, 2012 | 09:57 AM
Sry I didn't clarify. Running Mac solenoid. But the line that runs O the solenoid is the other fitting on the side of the waste gate.not at home so I can't look right now.
When I looked at the aem diagram it showed it was hooked up wrong. Any reason y tuner routed it this way?
If I remember right now. One line from hotside pipe to ebc then one line to side of wastegate
Old Mar 30, 2012 | 10:03 AM
Another thing. Last mile of last drive the dump tube was exceptionally louder then usual. Boost always stayed where it should have. Then the issues started like stated in my other post
s2kneub
Jan 5, 2018 03:32 PM
Hershey
Feb 26, 2015 07:33 AM
s2konroids
Sep 1, 2014 02:08 PM
gnows2k
Jun 18, 2013 01:58 PM
MegaTRon
Feb 18, 2012 10:41 AM
