Wastegate ?'s
Old Oct 8, 2006 | 09:04 AM
NFRTurboTerror's Avatar
Default Wastegate ?'s
I have a rev hard turbo manifold with a 35mm wg flange. I was wondering if a 38mm wg will work with the 35mm flange or will i HAVE to use a 35mm wg. The reason i am asking is that there seem to be more 38mm wg's to chose from than 35mm(but i could just be looking in the wrong places).
Old Oct 8, 2006 | 12:06 PM
JDMallmotorAP1's Avatar
should be fine
Old Oct 8, 2006 | 12:47 PM
Thanks i just found out from another source as well that you can use it for either.
Old Oct 9, 2006 | 07:21 AM
mase1's Avatar
many manufactures have switched from a 35mm to 38mm. they both use the same flange, you are fine.
RZA
May 7, 2015 04:48 PM
Sergei
Jun 27, 2012 09:55 AM
B5254T4
Mar 7, 2011 07:56 AM
petawabit
May 7, 2009 12:32 PM
s2000_turbo
Jul 22, 2008 05:25 PM
