Wastegate setup N1200 blower
Old May 27, 2013 | 06:49 AM
donaldmejr's Avatar
Originally Posted by camuman
Originally Posted by donaldmejr' timestamp='1369664053' post='22569262
[quote name='camuman' timestamp='1369663793' post='22569258']
Nice. But why only a 1200 injector? Go for the 2000! E85 needs a lot of pump and injector. You can do 500 on corn
lol you caught me before I could edit it. My tuner has both in stock so we are going to play around with both since Im on flashpro I have less control of injectors..from what I hear. So it maybe FID 1200's or 2000's I will update soon.
I can't wait to see how it works. Get a electronic boost controller or a mac solenoid also. This will further convince people to go this route. Hell I might have if it was an option back a few years ago.
[/quote]
Running a MAC and controled via Flashpro
Old May 27, 2013 | 06:20 PM
99SH's Avatar
I'm currently tuned for 12psi falling to 10psi me and the tuner ran out of time to get it to hold 12psi the whole time. Currently its making 390whp and 275wtq and a nice fat torque curve.
I updated my original post with my settings for reference(note I'm using a 11.9 spring which is probably different than yours):
https://www.s2ki.com/s2000/topic/971...t__p__22062429
To hold your boost flat, you need to boost by gear and have the wastegate close more with RPM. The RPM threshold where you start increasing duty cycle is when your wastegate spring = boost value
Old May 27, 2013 | 11:41 PM
donaldmejr's Avatar
https://www.s2ki.com/...st__p__22062429
Thanks for the replys...im glad you did this setup first as it made me want to go this route after my 928M BLV failed also. I also welded mine pre aftercooler as i didnt want to be venting cooled air but rather help the aftercooler keep up with things.
Old May 28, 2013 | 04:44 AM
Moddiction's Avatar
Former Sponsor
Awesome! What psi is the 2.8" pulley supposed to make normally without the wastegate?
I need to finally do these over this coming winter!
Old May 28, 2013 | 06:08 AM
donaldmejr's Avatar
I think 19-22psi ...I will know for sure when I get retuned.
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Old May 28, 2013 | 06:24 AM
Moddiction's Avatar
Former Sponsor
Nice. Do you have a dyno graph with the wastegate at the 12 psi? I'd love to see that torque curve.
Think I need to sell my vortech for an SOS 1200 kit!
Old May 28, 2013 | 01:09 PM
wait4vtec's Avatar
what size wastegate and spring did you go with
Old May 28, 2013 | 02:42 PM
donaldmejr's Avatar
A 38mm with a 12psi spring but I'm still trying to get things with boost control worked out
Old Jun 12, 2013 | 05:46 PM
wait4vtec's Avatar
updates?
Old Jun 25, 2013 | 07:27 PM
TOFUIGLOO's Avatar
im new to the SOS kit, so please forgive my ignorance, but what does that modification do to improve the base SOS kit?
