Wastegate setup N1200 blower
If you want to make 12psi on the SOS kit those 12 psi will be @ redline.
With a wastegate you can run fro example a 20 psi pulley and cap it to 12 psi in the rpm range by releasing pressure. If the 20 psi pulley give you 12 psi around 5000 rpm, with good boost control you will be able to have 12 psi from 5000 to 9000 which will give you better mid range than if you have 12 psi @ redline, boost will ramp up faster in the lower rpms too.
The big trade off is 20 psi warm air entering in the engine so cooling have to be upgraded, a second tensionner is a good idea too.
Originally Posted by suprmonky73' timestamp='1372252902' post='22631585
any concerns about wastegate failure
Sorry I didn't know people were still watching this thread.
So I attempted to run e85 but ran out of pump on the Dyno around 17psi. I rewired the stock line to 12awg wire and my fuel pressure jumped from 65 base to 100+ psi when I returned it to 65psi my A/F was 10 flat. So I should be good to continue my tune this weekend.
When I strap it back on I will get everyone a Dyno plot.
Also the car is night and day from my older 360whp....omfg its fast.
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
