Wastegate setup N1200 blower
Old Jun 27, 2013 | 01:10 PM
  #41
passmans2kny's Avatar
bc ur on 99, thats the only reason u can boost up to 21 safely
Old Jun 27, 2013 | 01:14 PM
  #42
mattie170's Avatar
UK 99 fuel is like 93/94 US fuel, someone might be able to exactly say what the difference is.
Old Jun 27, 2013 | 01:53 PM
  #43
camuman's Avatar
True. Mon V's Ron. Regardless that motor is on borrowed time brotha
Old Jun 27, 2013 | 04:54 PM
  #44
donaldmejr's Avatar
guys anyone know where to find the flanges for a test pipe...i would like to make a cut out.
Old Jun 27, 2013 | 08:47 PM
  #45
s2000Junky's Avatar
Originally Posted by Moddiction
No tuner who knows s20"0's well will give the thumbs up to tune 20 psi sc on a stock engine with pump. Sure it will be fine if you don't rev over 6-7k rpms. Taking it to 17,18,19,20 psi you would be asking for trouble. Theres a reason almost all tuners will recommend you stay under 14-15 psi on pump.
I said with water/meth injection above 15psi. Go back and re read.
Old Jun 27, 2013 | 08:58 PM
  #46
Moddiction's Avatar
Former Sponsor
Ahh missed that. Who wants to deal with meth though. Pain in the butt and one more thing to fail.
Built engine, e85/race gas or boost limiter is the way to go imo.
I was going to go the wastegate method but I think I'll be doing a low compression 2.4 this winter instead so I can throw lots of boost at it safely.
Old Jun 27, 2013 | 11:10 PM
  #47
mattie170's Avatar
I was told this some 9k miles ago about running at 18psi. I've just checked and its done 8k at 18psi and 1k with a rev limit at 9.5k and 21psi, we have just changed the pulley and brought the rev limit down to 9.1k so it produces 21psi there. The engine was out of it efficiency range at 9.5k. If it breaks I'll rebuild, so not a massive problem
Old Jun 29, 2013 | 01:12 PM
  #48
donaldmejr's Avatar
Here you go guys...by the way the most I ever saw was 11.6psi before we dialed it into 13-14psi on the highway...I also was ~1-2 psi lower on the Dyno due to my CAI.
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Old Jun 29, 2013 | 03:02 PM
  #49
Moddiction's Avatar
Former Sponsor
That is awesome! MUCH fatter powerband there! Must be a night and day difference!
Old Jun 29, 2013 | 03:25 PM
  #50
donaldmejr's Avatar
For a race gas Guy.....I say its a must do!!
