Water line routing? :(
Finished the sos ts max install last night with a friend. Started around 8pm and wrapped it up around 8am lol, first install for both of us.
But I'm not sure I have water lines setup right. So according to Garrett the feed should come through the bottom then up and exit.
Currently steel hose barb from block running to top of tc then bottom runs to oil water cooler then oil water cooler to lil pipe running along engine.
Btw sos instruction aint to clear here, it just says the barb runs to tc on inside of charge pipe and other runs to tc around the outside of charge pipe.
Loaded flashpros id1000 starting cal. Started right up and I limped it home in negative map pressure the whole way, it cruises under in negative map at 14afr
Wish I could load pics for y'all but posting from phone
Btw can the gurgling I hear from turbo make air in coolant system? Having a hard time bleeding again
hirev
Jan 14, 2019 05:35 AM
