Water Pump for Vortech SC
Old Aug 1, 2006 | 07:27 PM
batikan's Avatar
Default Water Pump for Vortech SC
I think i have a problem with the water pump. it looks it's not working %100 efficient. I have seen other people's car and it looked like the water was boiling when you open the cap. mine looks like the water is barely flowing.
instead of getting it fixed, i am planning on getting a new one. anyone know what brand water pump can i use? (i need to buy it ASAP so I need something i can find at a local store)
any suggestions??
Old Aug 1, 2006 | 07:32 PM
Slows2k's Avatar
You're assuming the pump is bad without testing anything.
Have you checked the wiring?
The relay?
Is the pump mounted correctly so it self purges air?
Is the system full of H20?
Old Aug 1, 2006 | 07:58 PM
batikan's Avatar
the wiring is fine.
it is full of water
it is mounted exactly as it shows in the manual
it is working but not flowing enough. the shop who installed the charger did not put any water in. i am guessing because of that, it might be burnt or something
Old Aug 1, 2006 | 08:07 PM
Slows2k's Avatar
The pump is made by Hella, but you probably won't be able to find one locally. I'd be calling Vortech if you want another one.
jordannn93
Jan 7, 2012 06:28 PM
MinS2K
Jun 9, 2009 11:34 AM
Kondor999
May 8, 2009 04:24 AM
MinS2K
Aug 3, 2008 12:04 PM
batikan
May 15, 2006 03:18 PM
