Weird Problem
Old Jan 24, 2012 | 02:20 PM
s2klariat's Avatar
Possibly dirty or clogged injectors?
Old Jan 24, 2012 | 05:01 PM
JoeyBalls's Avatar
FWIW, what is your TPS voltage showing at WOT? I have had multiple TPS failures and sometimes the voltage at WOT is like mid 3.0 (should be 4.5 IIRC), so WOT the car woulf think it was at like 80% throttle and it would run piggishly slow
Old Jan 24, 2012 | 05:03 PM
JoeyBalls's Avatar
Old Jan 25, 2012 | 07:54 AM
TerminatioN's Avatar
As expected, I replaced the plugs with a set of BKR8EIX Iridium plugs and now she runs good as new.
Thanks for the help guys!
Edit: Nvm, still doing it.
Old Jan 25, 2012 | 08:08 AM
spectacle's Avatar
Good to hear. How did the ones you pulled out look?
Old Jan 25, 2012 | 08:27 AM
Yep. Definitely a relief that it was something so small/simple.
Very dark brownish. Wouldn't say black though. Definitely older than I thought.
Going to start to keep a log on Google docs of my maintenance. Hopefully should prevent issues like this with my horrible memory.
Old Jan 25, 2012 | 03:56 PM
Apparently I spoke to soon... I could have swore it was fine, but its doing it again.
Now I'm thinking it may be a clogged injector, because it is running VERY lean, and the tune is the the same as it has been (worked fine for plenty of miles before this). I was surprised they didn't clog after I switched to E85 considering we don't have a fuel filter... The injectors themselves don't have many miles on them, but I can only imagine how much crap the E85 must have broke loose after ~50k+ miles worth of 93 being run through the fuel system.
Anyways, I sent a log to my tuner. Will wait to see what he says. But chances are very good I'll be stopping by USPS in the morning to mail off my injectors for cleaning...
s2konroids
Apr 5, 2012 12:46 PM
AFs2k
May 1, 2010 02:22 PM
batikan
Nov 16, 2007 06:40 AM
freshs2k
Nov 15, 2007 01:16 AM
Reborn56
Nov 5, 2006 06:06 PM
