Went on a dyno scd vortech ap1
Old Oct 3, 2007 | 08:49 PM
Slimjoe's Avatar
Default Went on a dyno scd vortech ap1
Is 315 whp low for a vortech supercharger with upgrades(4 inch aluminium pulley, 650cc rc injectors, diy supra krank vent, berks test pipe with oem exhaust and headers tuned on aem ems.Will a t1r 70mm and js racing headers give me much more whp?And should i be worry about my stock headgasket or get a new hg 3mm?by the way i have 18 inch volks te37 if it has something to do with my whp numbers
thanks in advance
Old Oct 3, 2007 | 10:15 PM
yiannakos's Avatar
how many psi do you produce ?
when i added a js header to my comptech i gained 15whp throughout the power band and mostly low to mid rpm
i have berks test pipe also.
a t1r 70mm will defenately give you some more ponys
Old Oct 3, 2007 | 10:27 PM
Slimjoe's Avatar
dont have my aem serial gauge set up yet but my tuner says im about 10-11lbs boost
Old Oct 3, 2007 | 10:31 PM
WindchaserS2K's Avatar
4 inch on a AP1 will get you about 14lbs. I'm running 8lbs at 332 HP. redline set at 8800RPM
Old Oct 3, 2007 | 10:54 PM
dans2k's Avatar
Can you post the pics of Dyno sheets?
The numbers seem extremely low for that amount of Boost.
Old Oct 3, 2007 | 11:56 PM
yiannakos's Avatar
the numbers are low to very low for that boost
Old Oct 4, 2007 | 12:37 AM
Enthralled's Avatar
I'm at 322whp/211tq(dynojet) 8lbs boost.
Old Oct 4, 2007 | 11:53 AM
Slimjoe's Avatar
no dyno sheet i think i have a belt slippage
Old Oct 4, 2007 | 12:30 PM
WashabiS2K's Avatar
10-11lbs. boost on stock compression? i thought it was recommended to get a slightly thicker headgasket and lower the compression a little bit? any knocking? or is it all cleaned up with retarding via EMS?
Old Oct 4, 2007 | 01:33 PM
you can do 10-11lbs on stock compression with a very good tune
