Went on a dyno scd vortech ap1
Old Oct 4, 2007 | 01:56 PM
Halo's Avatar
Hmmm, I would think that if it was just belt slippage, you wouldn't be making the boost you're claiming.
That said, absolute dyno numbers are full of all sorts of errors. Comparing 2 cars on different dynos under different conditions can have + error larger than the claimed gains of some bolt-ons. There was a great article a few years ago about tuning at DINAN. In response to "how much power does this car put down?" the tech said (smiling) "how much do you want it to?" implying that he could set up the run with enough artificial conditions to make it look good in a pissing contest. Or, he could set it up to produce far less.
Where the dyno is most useful is measuring % gains before and after a change, especially if the 2 runs are done close together in time. So, while 315 seems low for what you're describing, what did the car make stock on that dyno and what did it do with just the SC with the standard pulley? If the % increases sound about right (35-40% increase in peak rwhp for stock -> SC for example) then everything might be just fine.
Old Oct 4, 2007 | 05:06 PM
dragtek's Avatar
with aftermarket headers and exhaust im sure you will see A LOT of gains. what kind of dyno was it???
Old Oct 4, 2007 | 08:43 PM
Soul Coughing's Avatar
Originally Posted by WindchaserS2K,Oct 4 2007, 01:31 AM
4 inch on a AP1 will get you about 14lbs. I'm running 8lbs at 332 HP. redline set at 8800RPM
a 3inch pulley got 14 psi on my comptech setup...
Old Oct 4, 2007 | 08:55 PM
Venomous S's Avatar
I made that much power w/ a stock pulley and a VAFC. Very low #'s
Old Oct 7, 2007 | 04:51 PM
smitdog's Avatar
i have 4 inch pulley .. ap1 ... inline pro 3 mm hg .. test pipe .. buddy club single exaust and i put down 346 whp .. i have aftercooler allso so i see around 11-12 psi on my boost gauge .. if you are stock comp you should be alot higher hp for sure .. i went with 3mm hg because i plan to run a 3.8 pulley one day.. wanted my SC to break in some before maxing it out .. i allso think you may be pushing the limits with 4 inch pulley and stock comp ..
Old Oct 8, 2007 | 07:51 AM
s2kjb's Avatar
he has the 3mm hg.
im putting down 300hp 186tq stock pulley header back 3'' exhaust low-comp fulley built 2.2l
ur numbers seem a bit off
Old Oct 8, 2007 | 09:40 AM
WindchaserS2K's Avatar
yeah because you have a comptech
coreyfrenzel
Apr 15, 2011 07:23 AM
EriS2k
Jul 31, 2010 01:34 PM
leo520
Aug 19, 2009 03:42 PM
hamlet9634
Apr 21, 2009 05:21 PM
Drkphnx
Dec 12, 2006 03:37 PM
