What can I take out!
Old May 25, 2011 | 07:37 PM
Corey Maurer's Avatar
Default What can I take out!
Well, getting the car ready for the turbo install and removed all the exhaust stuff, do I remove the stock o2s as well? or does the AEM use these for something?
Old May 25, 2011 | 07:40 PM
3en's Avatar
3en
They are not used by the ems. You can remove them.
Old May 26, 2011 | 04:58 AM
ok sweet.. Ill be taking those out today, what else can come out? I have removed secondary air system and now the 02s.. anything else that can go?!
Old May 26, 2011 | 05:15 AM
Deception's Avatar
Vtec oil pressure sensor
Old May 26, 2011 | 08:03 AM
3en's Avatar
3en
+1 on vtec sensor. You can also remove the giant evap box under the car. A couple of guys have done this, I forgot what they did to help with the gas smell though.
Old May 26, 2011 | 09:03 AM
wadzii's Avatar
Banned
leave the vtec pressure sensor.. thats handy to have if you ever need to troubleshoot vtec.
I pulled the black box from under the car along w/all the lines gonig from the box to the engine bay.. i dont notice a gas smell unless I top off the gas too much when filling up.
you can get rid of all the coolant lines that run through the throttle body and IAC
you can get rid of all the soleniods and crap associated w/the air pump and evap system.
the ems also only uses one of the cam sensors.. i forget which one, but you can remove the other.
Honda's are pretty simple as far as engine wiring goes, they dont have too much useless mess.
Old May 26, 2011 | 11:50 PM
Moddiction's Avatar
Former Sponsor
I pulled all the air pump hoses etc. Removed coolant lines to tb, egr and put the block off plate there and then removed all the extra vacuum lines from intake manifold and capped all those off. Looks MUCH cleaner now I think!
s2kneub
Feb 17, 2013 06:19 PM
sIIooo
Sep 6, 2012 05:29 PM
08s2000CRbackinblack
Aug 6, 2012 01:30 PM
05TurboS2k
Nov 2, 2008 01:55 AM
Spoolin
May 14, 2007 11:11 AM
