what do I need to do to move to E85?
Old May 7, 2010 | 05:06 PM
  #21
Momentum's Avatar
Originally Posted by Jacko,May 7 2010, 05:01 PM
Well I could be wrong but I don't think its easy as switching maps between E85 & Pump gas. With all of the fuel system upgrades to flow all the E85 you'll need, I don't know if you can just switch maps. But if that is true then no worries Justin.
Btw: I agree with you Joey about both using meth and the fact its never enough
You can easily switch maps and even better buy a sensor out of a flex fuel vehicle and use it to have your car mapped properly no matter what the mixture.
Old May 7, 2010 | 07:28 PM
  #22
Jacko's Avatar
Good to know
Old May 8, 2010 | 01:15 PM
  #23
goldsS2000's Avatar
What part of NC are you guys from? Ive been debating this for a WHILE now, whether or not to run e85 or just have a pump/race gas tune with my boost solenoid. I thought of having 2 tunes between e85 and pump but I just figured that wouldnt work very well. In my area the only close E85 station is in Hickory which is where I work, about 25 miles from my house. If being able to have a pump gas tune and an E85 tune would work well then thats a no brainer in my book. Has anyone done this particular fuel setup yet?
Old May 8, 2010 | 01:29 PM
  #24
Momentum's Avatar
You could do it pretty easily you just have to make sure before you switch fuels the fuel light has been on for a bit, which makes some people uncomfortable. The other option is like I posted earlier; buy a flex fuel sensor so you can have any mixture of ethanol and gasoline and be fine. I'm from Wilmington and unfortunately we don't have any E85 stations around, I just buy E100 drums by the pallet.
Old May 8, 2010 | 01:54 PM
  #25
goldsS2000's Avatar
Oh ok. Im in the Hickory area, about 1 hour from Charlotte. Ive considered just leaving a drum at my house at all times, but it does spoil rather quickly so it has to be used. Im going to give this pump/E85 tune thing a gander when its assembled again. Some of you guys really need to take a trip down to Hickory one Saturday. It would be worth your time haha
Old May 8, 2010 | 06:54 PM
  #26
Spoolin's Avatar
I drained my race gas the other day by disconnecting my -8 return line at the tank and putting it in a gas can and then started the car until it was running very rough and shut it down. I did this because I am switching to e85 but will never do it again. The Walbro's didnt like running while the fuel was so low. I could smell that hot electrical smell around my trunk after doing this from, I'm sure, the pumps getting very hot. I wouldnt recommend ever running your tank very low with the Walbro pumps. I will always keep my tank above 1/2 tank.
Old May 9, 2010 | 12:53 AM
  #27
goldsS2000's Avatar
That is a very common thing to hear about the Walbros. Or it is for me anyway. I totally forgot about them being so finicky with the fuel level. idk wtf Im going to do
Funtimefrankie
Dec 5, 2014 10:49 AM
TerminatioN
Jun 10, 2011 05:06 AM
Redline S2K
May 21, 2011 06:44 AM
JDMallmotorAP1
Mar 19, 2010 05:30 AM
