What to do with my motor?
Old Jun 23, 2013 | 07:20 AM
jordannn93's Avatar
Default What to do with my motor?
Finally took my motor apart after it was making a noise and I found this
Old Jun 23, 2013 | 09:24 AM
miguel329's Avatar
Old spark plug tip?
Old Jun 23, 2013 | 09:33 AM
riceball777's Avatar
Did u ever blow a spark plug before.
Old Jun 23, 2013 | 09:58 AM
jordannn93's Avatar
It's not a spark plug tip. I never pulled a plug where the tip was missing.
Old Jun 23, 2013 | 10:13 PM
s2k manic's Avatar
your turbo right? check your impeller. does look like you had a detonation station though. if you run a plain bearing turbo you may have scuffed the impeller and broke a piece off
Old Jun 24, 2013 | 11:48 AM
jordannn93's Avatar
Yes I am turbo. Turbo looks fine. There is no sign of damage to the fins. Two months ago I had to drive the car for a little bit when cylinder 2 wasn't firing.
Old Jun 24, 2013 | 11:55 AM
jordannn93's Avatar
Anyways I am considering a used oem block with good cylinder walls. Also someone told me I can get my motor sleeved with darton dry or wet sleeves.
http://realstreetperformance.com/sto...-s2k-2876.html
http://realstreetperformance.com/sto...89mm-2581.html
Old Jun 24, 2013 | 12:05 PM
neeman77's Avatar
What does the cylinder wall of #1 look like? Did you unplug the fuel injector in cylinder 2 when you were driving it without it firing?
Old Jun 24, 2013 | 08:19 PM
s2k manic's Avatar
it doesn't look like there was enough room to let a piece of the top ring by good luck on the rebuild
Old Jun 24, 2013 | 08:20 PM
jordannn93's Avatar
Cylinder #1 is badly scratched. I did not unplug the fuel injector. Cylinder #4 is fine
