What do you think
Old Jun 13, 2010 | 12:27 AM
oklahomaS2K's Avatar
Default What do you think
I installed my greddy kit the other day and got it tuned. It was running fine until today it threw a bunch of engine codes all of which were missfires. i put good plugs in and it only had one cylinder three misfire code. so i switch coilpacks on 3 and 1 and it said misfire cylinder one so im figuring its the coilpack, does this make sense? also a greddy kit ona stock motor can make 10Ibs at 300hp right? mine would only make 6 and they said it was because of the cat is stock . but i found a leakin in the line on the secondary air sensor will this fix it? turbo and everything is good
Old Jun 13, 2010 | 12:58 AM
A51_AP1's Avatar
Sounds like a timing issue. I would talk to your tuner about this. Even though it might have been "tuned", some tuners wont tune all cells within a map. If some cells were left with the base map that Greddy provided, changing a bunch of cells without actually moving the vehicle into those cells or interpolation is at such a large gap that the computer must use something inbetween the given parameters. I'd suggest taking it back to your tuner and seeing if he can identify any problems.
Old Jun 13, 2010 | 10:24 AM
Ian300D's Avatar
If you moved the coil and the problem follows the coil then yes it's bad. I would do that first. I'm surprised your tuner didn't tell you about misfires on the dyno though.
Old Jun 13, 2010 | 10:30 AM
boostftw's Avatar
[QUOTE=oklahomaS2K,Jun 13 2010, 01:27 AM] I installed my greddy kit the other day and got it tuned.
Old Jun 13, 2010 | 11:51 AM
siadam's Avatar
I'm going to go w/the simple fix.
Plugs.
Replace w/on step colder, and check gaps.
azunboy
Jul 1, 2010 09:40 AM
drhess06259
May 24, 2010 05:42 AM
scors2
Mar 30, 2010 12:23 PM
s2kbtos
Aug 30, 2008 05:32 PM
azunboy
Mar 10, 2008 05:15 PM
