What else should I get with this
Originally Posted by josserman,Jun 24 2009, 04:19 PM
Inline Pro Turbo kit
I do plan on doing some track days so Ya recommended an oil coiler.
Also typing this up I realized the labor to install a clutch is in here, but we left off a clutch so suggestions on the clutch. Guages for boost and oil pressure.
What other cooling do you recommend as I will hit the track?
Anything else?
Thanks!!!
Anything else?
Thanks!!!
Make sure you ask for the Honda replament MAP sensor rather than the GM honda "ta4ba rma p sensor"
With everything you want to do you may want to look at the AEM EMS a bit more.
Based on my Build here is a short list
Valves (Exhaust at minimum)
Mac Boost Solenoid
PLX Wide Band
Hondata/Omni Map Sensor
Ball Bearing Turbo Upgrade
Track Goodies:
PWR makes a radiator with integral oil cooler
Throw on a set of Spal Fans for Extra Security
Oil Pressure and temperature Sensors
For reference look at my sig and I have my build to documented but it is out of date, I have added an IP fuel rail, relocated the battery and a few other goodies.
S2BOOSTED
Sep 10, 2010 04:20 PM
