What HP to Expect from
Old Nov 17, 2009 | 07:44 PM
JohnnyP912's Avatar
Default What HP to Expect from
InlinePro Street Kit
SOS 70mm tb
Ported/ bored Intake manifold w/hondata gasket
Greddy Ti-C 70mm CBE
Berk 70mm Test Pipe
255 Walbro Fuel Pump
Tuned on an AEM EMS 30-1052u
HP Estimate?
What is the highest amount of boost you can run without changing the injectors?
Sorry if this has been covered before
Thanks in advance for any positive feedback
John
Old Nov 17, 2009 | 07:59 PM
dsddcd's Avatar
Which turbo, injectors...
Who is going to tune it?
There are several different choices for all of the above
Old Nov 17, 2009 | 08:02 PM
s2000Junky's Avatar
Its not so much how much psi you can run with stock injectors but how much hp potential they can handle. If your motor flows better then stock from your ported intake and exhaust you might only be able to deliver enough fuel to run up to 6psi vs the guy with a more stock breathing set up who can run 7psi
Kind of a weird question since you will be running an EMS, no point in sticking with stock injectors at that point. But to answer your question they are good for about 300whp. Another 25whp or so if you want to push them to more unreliable levels. But these were designed to run 200whp so another 100 is already asking allot.
You wont make squat with stock injectors and turbo. The fuel requirements go up much quicker on a turbo set up due to the power curve. Stock injectors are pointless with your mods turbo or not.
Old Nov 17, 2009 | 08:04 PM
JohnnyP912's Avatar
ok so then 650cc injectors tuned by evans
Old Nov 17, 2009 | 08:06 PM
KaNgArOo's Avatar
Around 300whp sounds right, if you get injectors.
Old Nov 17, 2009 | 08:09 PM
s2000Junky's Avatar
[QUOTE=JohnnyP912,Nov 17 2009, 09:04 PM] ok so then 650cc injectors
Old Nov 17, 2009 | 08:21 PM
TRBOKEV's Avatar
whAt turbo????
I got some inline pro 675 injectors I got to get rid of.
Old Nov 17, 2009 | 08:26 PM
JohnnyP912's Avatar
Sorry im new to the FI forums and didnt take into account on all these factors
im not sure of the turbo.. the kit list just says precision turbo..
And what would be the numbers for 8psi 10psi and 12psi .. and at what point would it be a good idea to get ARP head Studs
Old Nov 17, 2009 | 08:34 PM
Deception's Avatar
300-330whp on 7psi, depending on turbo size & what dyno your on
Old Nov 17, 2009 | 08:37 PM
TRBOKEV's Avatar
Yeah and if it was a decent turbo, at least a 5965 than at ten psi you should make at least 360 with injectors.
