What Is Too Lean for S/C?
Old Oct 7, 2010 | 09:57 AM
JawKnee's Avatar
Default What Is Too Lean for S/C?
I have a SOS Base kit with some bolt-ons and will finally get a chance to dyno it tomorrow now that my clutch has been upgraded and broken in.
With the base kit and adjusting the RRFPR, I understand I won't be able to tune out minor fuel variations. With my wideband, I usually see a spike to 12.2/3 at 6200 rpm or so, but then it goes 11.7 - 11.9/12.0 the rest of the way.
I assume the spike for such a short duration is fine, but what's the leanest I should go? Assuming of course, I'd be making more power by going a little leaner.
I think SOS suggested or shoots for under 12.0 for over 2-3 lbs of boost.
Let me know if i can provide any further details on my setup if that helps answers the questions.
Old Oct 7, 2010 | 10:08 AM
spectacle's Avatar
That sounds like a lean spike at vtec engadgement, which I believe is normal. Can anyone else verify?
Old Oct 7, 2010 | 10:10 AM
JawKnee's Avatar
VTEC with the SOS Base kit kicks in at 4500.
Old Oct 7, 2010 | 10:12 AM
spectacle's Avatar
Right but the SOS kit fuel/timing management is a piggyback device correct? If so, the stock mapping would still exhibit the dip. I'm just speculating here I'm not familiar with the kit
Old Oct 7, 2010 | 10:14 AM
JawKnee's Avatar
You're correct and that makes sense.
So dips like that don't sound like a big deal, but what AFR should I strive for w/o going too lean, whatever that is?
Old Oct 7, 2010 | 10:16 AM
spectacle's Avatar
Give SoS a call and verify with them, but if you're saying they recommend 12.0 that sounds right
Old Oct 7, 2010 | 10:35 AM
camuman's Avatar
imho, 11.5-12.0 would be fine.
Old Oct 7, 2010 | 11:36 AM
R1_Pilot's Avatar
Mine is running between 11.7 and 11.9.
J
Old Oct 7, 2010 | 03:14 PM
Moddiction's Avatar
Former Sponsor
I see mid to high 12's with my vortech at redline. Would like it to be a bit richer but I'm not TOO worried with it as long as it doesn't get any leaner.
Old Oct 7, 2010 | 05:06 PM
Enlightened's Avatar
From what I've seen SOS AFR's are between 12-12.5. I talked to Brian at SOS recently about this and he mentioned this range, but you may want to verify this.
