what type of oil?
I was wondering what type of oil does everyone using? currently I'm using mobil 1 10-40w. I have a greddy turbo and i'm looking for something that would last longer.
I am switching from M1 10w-30 to Redline 10w-40. I have done a LOT of research on oil before coming up with this, and it seems to be a really good choice for FI applications. Not the only good choice, but a good choice. You have to order it online though, but it is supposed to be good stuff.
good luck
Rich
good luck
Rich
I would highlty recomend the following (2) oils which are availible at most automotive stores, read my above link for back ground, which does not included opionions just the facts.
http://www.mobiloil.com/USA-English/MotorO...acing_Oils.aspx
http://www.mobiloil.com/USA-English/...l_1_0W-40.aspx
Castorl 0W-30 is also in the same category
Look for oils that are not Energy Concerving and you will be better off.
I was using the euro 5-40 from Amsoil but at nearly $9 I felt I needed to try something else, just switched to the Mobil 0-40. Sounds like its a good choice so maybe i'll stick with this for a wile, my only concern was that it might be a little on the light side for summer. I was thinking 10-40 might be best to switch in the hot weather and then go back to the 0-40 in the colder months? I want to make sure i'm using the right weight oil for max protection for my set up.
Originally Posted by dsddcd,Mar 5 2009, 12:41 PM
No, the viscosity at all temperatue is better, the 0w is decieving
