what type of oil?
Old Mar 4, 2009 | 03:41 PM
TuRbo_S2000's Avatar
Default what type of oil?
I was wondering what type of oil does everyone using? currently I'm using mobil 1 10-40w. I have a greddy turbo and i'm looking for something that would last longer.
Old Mar 4, 2009 | 03:51 PM
DeadZero's Avatar
Mobil 1 10w-30 is what i use
Old Mar 4, 2009 | 03:54 PM
ChefJ's Avatar
Try not to ask any oil questions on this forum. It has been talked about 100000 times and always starts arguments.
do a search and do a search in the UTH forum.
Old Mar 4, 2009 | 08:51 PM
dsddcd's Avatar
Start Here
https://www.s2ki.com/forums/index.php?showt...&#entry15017337
Old Mar 5, 2009 | 05:27 AM
RichV's Avatar
I am switching from M1 10w-30 to Redline 10w-40. I have done a LOT of research on oil before coming up with this, and it seems to be a really good choice for FI applications. Not the only good choice, but a good choice. You have to order it online though, but it is supposed to be good stuff.
good luck
Rich
Old Mar 5, 2009 | 05:50 AM
kutsujula's Avatar
I'm using Brad Penn
Old Mar 5, 2009 | 07:12 AM
dsddcd's Avatar
I would highlty recomend the following (2) oils which are availible at most automotive stores, read my above link for back ground, which does not included opionions just the facts.
http://www.mobiloil.com/USA-English/MotorO...acing_Oils.aspx
http://www.mobiloil.com/USA-English/...l_1_0W-40.aspx
Castorl 0W-30 is also in the same category
Look for oils that are not Energy Concerving and you will be better off.
Old Mar 5, 2009 | 08:48 AM
s2000Junky's Avatar
I was using the euro 5-40 from Amsoil but at nearly $9 I felt I needed to try something else, just switched to the Mobil 0-40. Sounds like its a good choice so maybe i'll stick with this for a wile, my only concern was that it might be a little on the light side for summer. I was thinking 10-40 might be best to switch in the hot weather and then go back to the 0-40 in the colder months? I want to make sure i'm using the right weight oil for max protection for my set up.
Old Mar 5, 2009 | 11:41 AM
dsddcd's Avatar
No, the viscosity at all temperatue is better, the 0w is decieving
Old Mar 5, 2009 | 11:58 AM
s2000Junky's Avatar
Interesting, well all oil gets thinner as it gets hotter. The 10-40 does appear to be thicker oil then the 0-40 cold, the 0 & 10 is the cold start rating, but wondering if the 10-40 would still be thicker hot do to its thicker cold characteristics over the seemingly thinner 0-40, thats how my thinking as transpired.
oo7ml
Apr 25, 2008 11:55 PM
vietboyjl
Dec 7, 2005 07:13 PM
gti2000
Mar 13, 2005 02:21 PM
