What is your engine coolant temperature ? ( water temp )
Old Jul 12, 2011 | 03:02 PM
BILLYhoang's Avatar
Default What is your engine coolant temperature ? ( water temp )
I'm averaging 190-194 without the a/c on.
With the a/c on, it goes up to 201-202, but I've seen it peak at 205.
I'm just trying to see what is the safe number range.
And also, any advice to get maximum cooling efficiency ?
If it matters, I am running......
ARC radiator with stock fans
OEM HONDA blue coolant.
Inline pro 3mm head gasket.
AEM EMS
- Billy
Old Jul 12, 2011 | 03:07 PM
spdracerut's Avatar
Try reading these two articles:
http://www.motoiq.com/magazine_artic...erheating.aspx
http://www.motoiq.com/magazine_artic...ather-fun.aspx
I want to say the fans come on around 95C to 100C, though they are always on when the A/C is on. 95C is 203F, so that seems okay.
Old Jul 12, 2011 | 03:15 PM
Moddiction's Avatar
Former Sponsor
200 is plenty safe still I believe. It's once it starts climbing over 210 I would start getting more nervous. Especially if you have a thicker head gasket.
My coolant temp stays normally right around 180. Highest I have seen it get on a really hot day on the highway to 201 and then went right back down to 180.
Old Jul 12, 2011 | 04:20 PM
RacerXI's Avatar
OP, What engine management are you using? What temp do you have your fans set to come on/off? The highest I have seen is 192.
Mine are your typical on above 190 and off below 178.
Old Jul 12, 2011 | 04:22 PM
BILLYhoang's Avatar
AEM , I think it's set to come on at around 175-180
Old Jul 12, 2011 | 04:24 PM
BILLYhoang's Avatar
Yea, Inline Pro also said that the temp range should be 190-210. I would really like to stay close to 190 but with the A/C on, its closer to 199-200. Also, if it matters, today's temperature was 92 degrees.
Old Jul 12, 2011 | 04:55 PM
riceball777's Avatar
mine is in the 190's 99% of the time. sometimes it hit 201-205 but it will usually go back in the 190's very fast.
i have an aem ems version 2 with a serial gauge reading the water temp through the stock sensor. car has a bacis turbo setup with an mishimoto radiator and stock fans.
Old Jul 12, 2011 | 04:59 PM
BILLYhoang's Avatar
Is that with the a/c off ?
Old Jul 12, 2011 | 05:12 PM
with the ac on it maybe a few degrees higher.
Old Jul 12, 2011 | 06:28 PM
camuman's Avatar
did you update your coolant temp sensor calc table? if not then do it and you will prolly see the temps drop. i dont get upset now still it creeps over 215 and stays there. typically, crusing i see 180-185 no ac, and with ac 185-195. bumper to bumper traffic i have seen 205-210 with ac on.
