where did you mount your flexfuel sensor
Old Jul 22, 2014 | 07:18 PM
  #101
CoolGuy094's Avatar
I really can't speak for the AEM as I said. All I know is what I have learned from the all-powerful interwebs and how the GM sensor will interface with the Haltech Platinum Pro ECU.
Haltech says that their Platinum Pro ECU's are "Flex Ready" as well, but then say that the I/O expander unit is required which gives you an available digital pulsed input channel to wire the sensor to.
Old Jul 23, 2014 | 04:52 PM
  #102
siadam's Avatar
I'm not arguing, just trying to understand how this works and really appreciate your input.
I REALLY wanted the sensor to output to my 19-1 serial gauge...instead of purchasing another 200 dollar display strictly for an ethanol reading...at the very least, we should be able to plug in our laptop, and get a reading via the EMS....?
Old Jul 23, 2014 | 05:45 PM
  #103
CoolGuy094's Avatar
Yeah I know you weren't arguing, lol. To be honest I was hoping that I wouldn't need the Zeintronix either and that I could just wire the sensor directly to my ECU. I didn't care about a readout and figured I could just plug up my laptop if I really wanted to see the percentage. But I just don't think it will work like that. After doing more research and learning all that I have posted, it seems like the Zeintronix (or some other signal converter/interpreter) is necessary. Unless someone on here has experience doing otherwise...
Old Jul 23, 2014 | 05:50 PM
  #104
APoner's Avatar
On AEM it wires direct to the ecu. I have my gauge and my AEM both going to the same signal wire.
Both gauge and ecu % match up
My output on the zietronic gauge aren't being used.
Old Jul 23, 2014 | 06:00 PM
  #105
APoner's Avatar
My settings
Signal wire is going to the d connector on pin 12 on the AEM series 2 (d12) that input is associated with switch 3
Settings are
Flex fuel input : switch 3
Sw3 falling edge: on
Sw3 rising edge: on
Flex fuel switch : switch always off
Works petfect. All settings in flex fuel tab on AEM tuner.
Look for flex fuel content % and see if it syncs with gauge and all set. If your running pump and don't have a guage you should be at 8-10%
Old Jul 23, 2014 | 06:11 PM
  #106
CoolGuy094's Avatar
Freakin sweet! Well there you go siadam, lude92, and liquidgsr, you should be good to go! Wish the Haltech had an input that worked... Guess I'll check the sensor output wire versus the Zeintronix 0-5v output for ethanol % and see how they compare to confirm the info I read is correct.
Old Jul 23, 2014 | 06:31 PM
  #107
lude92_si's Avatar
I hope he's right I don't want to get to the tuners plug everything in and it not read. But I have heard this from 2 other people. And my v2 wont get installed till I get to Evans which is over 8hr drive. So it has to work :/
Old Jul 24, 2014 | 05:37 AM
  #108
APoner's Avatar
You dont have to take my word for it. I have the aem series2 2.2 firmware notes in pdf. It clearly states everything there and respectively how to wire it up. If someone wants to host it ill email them.
Im sure a simple call to Jeff will put you at ease. He has helped me a few times. There is also another post where someone did all this and did a how to in detail.
Old Jul 24, 2014 | 07:09 AM
  #109
lude92_si's Avatar
I'm sure your right I also have been told this
Old Jul 24, 2014 | 08:15 PM
  #110
siadam's Avatar
Pm sent with my email, I'll host it.
