Where do I get a Map Sensor adapter plate?
Old Jan 18, 2006 | 07:46 AM
ideugene's Avatar
Default Where do I get a Map Sensor adapter plate?
I was wondering if anyone knew where I could get an adapter plate that fits over the stock location for the map sensor, where I can plug in a 90degree fitting and run a hose back to the AEM map sensor. It would probably have to be 1/8 NPT hole. I found a picture of what I was talking about... hope you don't mind fperra!
Old Jan 18, 2006 | 03:20 PM
AusS2000's Avatar
I expect it's a DIY job. Some 8mm aluminium, band saw, drill and tapping kit. You can take the template off the MAP sensor or the face it mounts to.
Old Jan 18, 2006 | 05:33 PM
ideugene's Avatar
Anyone know if the Mitsubishi Evo map sensor is remotely compatible?
https://secure.buschurracing.com/catalog/pr...products_id=101
Thanks!
Old Jan 18, 2006 | 06:57 PM
Slows2k's Avatar
$3 in aluminium and a hour with a tap and hacksaw can do the same.
Old Jan 18, 2006 | 07:04 PM
ideugene's Avatar
True. I'm going to have to go shopping for some nice thick aluminum. How thick should this be? 8mm?
Old Jan 18, 2006 | 07:06 PM
Slows2k's Avatar
1/4 or is pretty easy to find at Home Depot or Lowe's, or most any hardware store. The thicker it is the more material to thread the pipe fitting in.
Old Jan 18, 2006 | 08:08 PM
Sideways's Avatar
You don't have to put the MAP sensor there. It will hook up to any vacuum port on the intake manifold.
Old Jan 18, 2006 | 08:16 PM
ideugene's Avatar
Yes I know. I just wanted to put it there to clean up some wiring and stuff. Possibly make a few bucks on the old map sensor as well.
amdaman
May 20, 2015 01:35 AM
s2konroids
Jul 12, 2010 12:13 AM
veehexx
Aug 8, 2009 03:32 AM
F1s2000
Dec 12, 2003 01:57 PM
