Where to get T fitting for oil feed?
bought a used gt35r setup. He did not include the oil feed T fitting....
Where do i get one of these???
Is there a specific size i can look for rather than buying 6 different ones to try?
Depending on your turbo it is either a -3 or -4 AN. The Garrett T3/T4's use a -4 for the feed and a -10 for the drain, unless they arent using the AN flange for the drain.
ATTENTION!!! If you are using a ball bearing turbo, you will need this:
http://www.atpturbo.com/Merchant2/merchant...tegory_Code=BCS
It has a built in restrictor to prevent excessive oil pressure that will blow your ball bearing setup up!
i built the car you got the setup from - off the oil filter relocator (on the block) there was a 45degree 1/8 to -3 an fitting, to the turbo, you should have also gotten the custom fitting for water feed to turbo,
Anything else just ask.
so if i have the inline pro setup with a gt35r turbo this is the piece i need to go from the oil feed line to the oil relocation fitting
And its a 1/8 BSPT... NOT standard Male Pipe Thread (MPT). I made that mistake already, I just bought a die and re-threaded the hole.
John
This is the one i use. Has BPT fitting on both ends and 2 NPT fittings on each side for feed and gauge if needed. It allows for use of the factory oil sending unit also. Just my .02.
http://www.tunertoys.com/category_s/495.htm
seoul2k
Apr 26, 2011 04:40 PM
s20004lifehomes
Aug 13, 2009 09:08 PM
afwfjustin
Aug 7, 2007 06:45 AM
