Where should the flex pipe go on my exhaust?
The guy i got my turbo kit from had problems with bolts coming loose and the manifold was cracked. Did some research and found out there should be a flexpipe somewhere on my exhuast.
WHERE and how big of a flexpipe?
Here's my downpipe if that helps......
http://img64.imageshack.us/img64/7408/hpim2231.jpg
^sorry, cant figure out how to post pics
Well you're still using the stock flex pipe connector for the cat, so technically you don't need one, but i guess if you wanted to install one i'd put it on the straight part of the pipe near where the pipe connects to the cat, or on the straight part going down from the turbo.
^closest to the turbo??? there really isn't much room there between the bends. I was thinking to put it after the bend closer to the O2 censor. Think that would be a bad idea?
What size flexpipe should i get? Cant be too long if it's gotta be between the bends on closer to the turbo.
ryiin2
Jun 19, 2017 01:58 PM
