Who makes cams for FI
Old Mar 10, 2005 | 05:59 PM
hboy7777's Avatar
someone here has webcams on there 500 hp s2000. i think its cjb80. not sure though. however im nervous about you wanting a more radical cam,
my thoughts on a perfect turbo/sc cam would be something with not as much overlap before vtec and then the same vtec lobes. this would give you tons more torque before vtec hits and then the vtec lobes being the most aggressive(high lift short duration) would take off from there. it would help lag(on turbo's) greatly..
Old Mar 11, 2005 | 08:15 AM
bobmoheb's Avatar
Could this same set up be applied to a s/c and be beneficial.
Old Mar 11, 2005 | 08:16 AM
bobmoheb's Avatar
Also do you have a web site for them?
Old Mar 15, 2005 | 06:35 AM
SpoonS's Avatar
I HEARD top fuel makes a boost cam for the s2000
Old Mar 15, 2005 | 07:23 AM
BlackNite's Avatar
FI cams that are used for the RSX turbo applications are also for SC applications... I would assume that this would be the same case for the S2K TC vs SC.
Old Mar 15, 2005 | 12:43 PM
honda9krpm's Avatar
why not send your f20c head to alaniz to improve the flow and safety
a couple of sc members here had better luck this way
I've also heard that Toda B spec cams are good for turbo. How much gain and risk of engine damage from this change is the real question? I am not game enough to be the first guinea pig for this.
Old Mar 16, 2005 | 12:33 PM
bobmoheb's Avatar
From what toda has told me all their cams are only good for n/a and they have no f/i cams.
Old Mar 16, 2005 | 12:35 PM
bobmoheb's Avatar
Also the reason i don't want to send it to Alaniz is the price i can get it done a lot cheaper locally with what i believe will be at least the same results if not better. I can get custom cams made but it get pretty expensive at that point.
Old Mar 17, 2005 | 01:00 PM
bigpurp's Avatar
I will be looking into having a set of high boost cams made for my application in the next few weeks. I'll let you know what I find out.
My tuner believes that, with the proper cams, we can add @ 40-50 whp at the same boost level. He's seen it happen with the EVO and B-series motors he works on, and he thinks the F20C will similarly benefit. We'll see...
Muscle Cars Blow
Jul 24, 2010 05:42 AM
21k
Sep 29, 2009 05:57 AM
08s2000CRbackinblack
May 9, 2008 05:19 PM
^AnDre^
May 15, 2007 11:59 AM
TCS2K
Sep 10, 2001 04:51 PM
