Why is this happening? Connecter is blowing off from
Old Mar 17, 2012 | 01:00 PM
JoeyBalls's Avatar
Default Why is this happening? Connecter is blowing off from
SO when I go into higher boost WOT and come off the throttle, the car stutters and dies. I thought I had a blown something up, but upon further inspection, the line coming from this relay(the line with the green tape)http://www.flickr.com/photos/joeycostanza/6990833473/http://www.flickr.com/photos/joeycostanza/6990833473/ by http://www.flickr.com/people/joeycostanza/, on Flickr . to the posative terminal from the battery keeps "blowing off" and looks like it is slightly charred, being the Fuel pump is connected to this relay the fuel pump dies and so does car. Do I need to make it tighter? The 30amp fuse is not blowing, what gives?
Old Mar 17, 2012 | 01:50 PM
D1sclaimer's Avatar
That just looks like a relay. I'd make sure all the wires are on with a good connection.
It doesn't look like you used a harness for the relay. I would recommend using one to make sure it stays put, but not using a harness does work too.
Old Mar 17, 2012 | 02:16 PM
JoeyBalls's Avatar
So if I just make sure it's on "tighter" it wont cause a fire or anything? Thats my only concern, I thought maybe it was coming off because too much voltage/amperage, but I checked my logs and battery is constant 14v and none of the 30 amp Fuses blew.
Old Mar 17, 2012 | 02:49 PM
D1sclaimer's Avatar
Just make sure that wire isn't being tugged on and that it is solidly on there. You're just over thinking it man.
Old Mar 17, 2012 | 03:03 PM
JoeyBalls's Avatar
ok, will do. I wanted to take it to the track tomorrow, bought a helmet and fire jacket
one last thing.
It was decently tight, and not really loose but still came off, if I really secure it, its not going to short anything or cause fire/battery to blow up right?
PS was playing with the relay, and noticed one of the connections is not connected to anything?, its all black, does
the relay needed to be grounded
Old Mar 17, 2012 | 04:08 PM
JoeyBalls's Avatar
ok, I think it was arching due to bad ground, lets hope regrounding it fixes it
Old Mar 17, 2012 | 06:08 PM
CKit's Avatar
Are you saying that the plug disconnected? Current won't "blow off" a plug. If you're describing what I think you are, it's just vibrating loose. Take pliers and crimp it together better.
Old Mar 17, 2012 | 06:25 PM
JoeyBalls's Avatar
will do
Old Mar 18, 2012 | 12:11 PM
99SH's Avatar
FYI...they sell vibration resistant crimp connectors, if you want to get fancy.
Mcmaster-carr p/n 8414T12
sunman
Sep 4, 2011 11:51 AM
sunman
Aug 24, 2011 01:33 PM
batikan
Dec 18, 2006 05:11 PM
