Why no torque!?!?!?
Originally Posted by liquid_helix136' timestamp='1383139956' post='22853422
log manifold chokes up the car for mid range torque. If you want more peak torque for how much power youre making, get a more efficient manifold. And injectors + map sensor alone wont make more boost. He's probably just gonna turn the boost up to like 15psi. You will probably make 400/260ish on that manifold.
400/260 would be awesome. Definitely will need a reinforced diff housing with that. Already botched mine using the launch control feature.
If your rear-end is botched I suggest un-botching it before you proceed with anything esle. Mom is not going like it if her rear end is not working. Look into a PuddyMod on this site if you think you need rear end work. He IS the BEST S2000 rear end guy.
H4RD ON
Sep 8, 2011 07:04 PM
As far as the Pfab top mount I think you would be a lot happier about that over your Rev Hard.
