Wideband?
Old Feb 17, 2016 | 12:45 PM
snajim's Avatar
Default Wideband?
Hey guys! I've decided to get the SOS stage 2 supercharger. I'll be running the Kpro. Only other mod is the T1R resonator and exhaust. This is my first time adding any forced induction to a car. Is a wideband sensor required? Will the tuner be able to do better with one? And if I should get one is it better to use a separate gauge or hook it up to the Kpro? Thanks!
Old Feb 17, 2016 | 06:29 PM
JUSTINTHECOASTIE's Avatar
Yes required, yes better with one but not needed for the tuner should have their own way to monitor air/fuel, You should be able to get a gauge that can do both, run on it's own or through Kpro. Hondata will suggest the PLX wideband. Nothing wrong with that. I run the AEM failsafe, Kpro reads from it as well.
Old Feb 18, 2016 | 11:54 AM
snajim's Avatar
Cool! Thank you!
Old Feb 18, 2016 | 12:01 PM
liquid_helix136's Avatar
AFR is the most important vital sign to a car. I wouldn't run a modified car without one ever again. So much valuable information can be deduced by knowing what the fueling is looking like. It's also good to be able to confirm that the car is running healthy. When you supercharge the car and nearly double the output, its best to be able to monitor vital signs like AFR, boost, oil pressure, fuel pressure etc.
Old Feb 20, 2016 | 12:30 PM
steven975's Avatar
I have one of the weakest FI S2Ks (SOS Stage 1, OEM ECU, a little over 300whp), and I won't run it without a wideband. It's $200 with a gauge.
The AFRs between summer and winter vary widely. Running FI with any problem like a bad injector will ruin everything, and AFR will give you real-time feedback if you've got a fuel issue.
macdaddies911
Apr 29, 2014 02:51 AM
fulken
Sep 29, 2013 10:58 PM
deucesblack
Feb 5, 2013 12:43 PM
BlackS2000Turbo
Aug 20, 2002 07:36 AM
