View Poll Results: Which way to rebuild....
Replace with another F20c build.
72.73%
LS1 Swap with T56.
18.18%
Other Idea, please detail in thread.
9.09%
Voters: 11. You may not vote on this poll
Widebody Turbo, What Next?!
Old Dec 18, 2013 | 10:10 AM
Ian300D's Avatar
Default Widebody Turbo, What Next?!
It's been quite a while, but I had a AP1 with following.
Inline Pro built engine
Inline Pro Stage 1 turbo kit.
AEM ECU
Shine Widebody.
I sold her years back and the built engine had already been replaced one due to bad tune we suspect with too much timing blowing engine. Well that owner had a failure of engine again and it looks like the same damage. Piston one looks oddly cleaner than rest; and damage is so bad it's hard to tell how it started. Will update with pics.
How it used to be....
This is first failed engine after not many miles from suspected bad tune. Only piston with damage, but pieces from it trashed the other cylinders. It was rebuild by inline pro again after this with all new components.
SO here is my question people. I will have about $9k for a budget of rebuild. But I want a reliable track car, as this will be replacing a M3 that saw a lot of road racing. I don't have to go turbo again, and will do all the work myself, can weld and fabricate any steel projects. I'm thinking I will have better luck swapping in a LS1. Are their cheaper/reliable swaps out there. I've been to EFI advanced and now feel confident on tuning; so not scared to tackle another turbo build, I just wonder if the money would be better placed into a NA build of some sort. HP wise I'm fine with 260-450whp; not wanting much more as I know rear end is a POS after 400 from what I recall.
Old Dec 18, 2013 | 10:14 AM
Ian300D's Avatar
And I'm getting it this weekend and wish to start plans and get ball rolling by new year. I plan on a lot of DE driving events so sooner the better. Here's the car she'll replace. Most reliable track/daily EVER!
Please note this ride height was quickly changed, slammed is not fast so it seems haha.
Old Dec 18, 2013 | 10:26 AM
Jmays2k's Avatar
Why not do a Supercharger build for the track I have been working on one for a little bit but that seems to be very reliable and will be cheaper then the NA build in the long run.
Jmays2k's Avatar
Oh and I love the color what color is that pm if you would like
Old Dec 18, 2013 | 10:40 AM
Ian300D's Avatar
Midnight Pearl, from Acura NSX early 90's. I changed blue pearl to a blue xerillic (spelling) pearl from HOK, which gave it a wild pop in real life.
Old Dec 18, 2013 | 10:42 AM
Ian300D's Avatar
I will entertain supercharger idea. But not sure what really makes them more reliable, other than less components in the mix to break. I think turbo has the issue with heat primarily, can't tell you how much of a PITA it was to stop all the nuts and bolts from backing out from constant heat cycles of daily duty.
Old Dec 18, 2013 | 10:49 AM
clarkster009's Avatar
You mentioned tracking it, you may want to read this: https://www.s2ki.com/s2000/topic/102...tup-for-track/
Not a lot of guys have had a reliable successful turbo setup for the track. I think the LS swap would be fun, or a supercharger is probably more reliable.
Old Dec 18, 2013 | 11:00 AM
Jmays2k's Avatar
^^^^ Yup on the turbo and supercharger. I think the LS1 would mess with the car balance to much. and that color it looks purple so its a blue?
Old Dec 18, 2013 | 12:06 PM
d-bo's Avatar
I know you are a fabricator but I have lsx engine/trans mounts for sale if you're interested
Sent from my iPhone using Tapatalk
Old Dec 18, 2013 | 02:00 PM
Ian300D's Avatar
The color is mostly purple. Its complex, and youd have to see it in real life to understand, but it can be black, purple, or blue depending on light and angle.
