Will the car run....
Old Sep 5, 2008 | 01:19 PM
AndyFloyd's Avatar
Originally Posted by kutsujula,Sep 5 2008, 01:16 PM
i had no exhaust either and my air pump was blocked off also.
you da man.
Old Sep 5, 2008 | 01:25 PM
jwa4378's Avatar
^ You can plug in the EMS. It should come with an NA f20c map with the software in the box... Should be the same as running the OEM ECU. Just FYI if you want to save a few bucks.
John
Old Sep 5, 2008 | 03:52 PM
AndyFloyd's Avatar
John
so i can just replace the factory ecu with the AEM and it will run just fine? I assume I have to load the map onto the EMS right? I dont have a laptop though...
Old Sep 5, 2008 | 04:35 PM
TelosHedge's Avatar
yes.
if you read the AEM manual there is also a little 'tuning 101' section that will show you how to compensate for the injector sizing as well. creating a quick 'zero'd out' map is very simple, and will absolutely get you to where you need to go.
however, stay out of boost!!!!!!
TUKES2k
Sep 24, 2015 01:42 PM
TerminatioN
Jun 10, 2011 05:06 AM
gnehc1
Apr 30, 2010 09:43 AM
skool u
Apr 21, 2009 05:04 PM
andersayz
May 26, 2006 04:54 PM
