will A/F read true in resonated tp?
hey guys, will the a/f ratio read correct for something like this?
I was wondering since the wideband sensor does not make direct contact with exhaust gas flow.
thanks!
thanks!
heres my experience on this.
i had the wideband tail sniffer and my wideband in the header colector. when i did dyno runs, my wideband in the header collector read .5-.8 points richer then the tail pipe sniffer.
on one run, i saw 11.5 @ collector, and 12.3 @ tail sniffer. i was running test pipe at the time. i only rely on my wideband in the car when at the dyno.
the tailpipe sniffer works fine so long as you dont have any exhaust leaks.
but most cars have some sort of leak.
last time i was on the dyno both the tailpipe sniffer and the wideband in the car were dead nuts the same.
bigwhite
Sep 13, 2007 10:34 AM
