will A/F read true in resonated tp?
Old Aug 17, 2009 | 11:11 AM
unethikl's Avatar
Default will A/F read true in resonated tp?
hey guys, will the a/f ratio read correct for something like this?
I was wondering since the wideband sensor does not make direct contact with exhaust gas flow.
thanks!
Old Aug 17, 2009 | 11:32 AM
camuman's Avatar
heres my experience on this.
i had the wideband tail sniffer and my wideband in the header colector. when i did dyno runs, my wideband in the header collector read .5-.8 points richer then the tail pipe sniffer.
on one run, i saw 11.5 @ collector, and 12.3 @ tail sniffer. i was running test pipe at the time. i only rely on my wideband in the car when at the dyno.
Old Aug 17, 2009 | 11:41 AM
Spec_Ops2087's Avatar
tail sniffer seems to read leaner then a sensor in the testpipe reigon -- I personally have seen this too on a few occasions.
Old Aug 17, 2009 | 12:20 PM
sohc_mshue's Avatar
I never use the tail sniffer for this reason
Old Aug 17, 2009 | 12:31 PM
wadzii's Avatar
Banned
the tailpipe sniffer works fine so long as you dont have any exhaust leaks.
but most cars have some sort of leak.
last time i was on the dyno both the tailpipe sniffer and the wideband in the car were dead nuts the same.
Old Aug 17, 2009 | 01:16 PM
unethikl's Avatar
ah, sorry guys, this is a test pipe. I forgot to mention.
Since the exhaust gas flow doesnt actually make contact with the wideband sensor, will it read a little leaner?
Old Aug 22, 2009 | 01:22 PM
s2000Junky's Avatar
I wouldn't trust it. Relocate your sensor to a portion of the tp that isn't resonated if it has one, or mount it on the header collector.
lsu17851
16
Dec 14, 2008 06:36 PM
qbmurderer13
Mar 29, 2008 02:20 PM
bigwhite
Sep 13, 2007 10:34 AM
Johnny Sack
Dec 11, 2005 09:48 AM
