Will the fuel Pump in the Comptech SC be adequate?
Old Feb 8, 2005 | 05:12 PM
yellowknockers's Avatar
Default Will the fuel Pump in the Comptech SC be adequate?
Do you think the Walbro fuel pump that comes in Comptech SC kit will be sufficient for the fuel supply/flow need in a 400-500whp application? Will be running 750cc injectors with 100 or 104 octane.
I called Comtpech and they told me that the fuel pump in their SC kit which I have is a Walbro GSS342 with a flow rate of 255 liters per hour.
If that's not adequate, can anyone recommend a make/model and flow rate that it should support?
Thanks.
Old Feb 8, 2005 | 05:25 PM
squibb's Avatar
The fuel pump will be fine for your application. I am going to use my fuel pump for a turbo system w/ same HP levels.
Old Feb 8, 2005 | 05:45 PM
kane.s2k's Avatar
It's more than enough for you.
Old Feb 8, 2005 | 06:04 PM
Thanks, I wanted to make sure since I'm upgrading quite a bit with a complete motor build and blower upgrade.
Old Feb 8, 2005 | 07:42 PM
Slows2k's Avatar
The 255lph Walbro can free flow enough fuel for 650hp or so. Pumps don't run without restriction though. The Stock fuel lines won't. 4-500hp, the Walbro pump is enough.
Old Feb 9, 2005 | 05:14 AM
sirrach's Avatar
not to bring this too off topic, but what blower upgrade are you doing?
Old Feb 9, 2005 | 07:21 AM
Novi-2000
#1turbos2k
May 25, 2012 09:58 AM
elusiv
Aug 6, 2006 11:31 AM
S2000_Europe
Jan 5, 2006 07:00 AM
S2000_Europe
Apr 15, 2004 03:18 PM
AusS2000
Oct 19, 2003 09:58 PM
