Wiring up resistor box...?
Old Nov 26, 2008 | 04:34 PM
EK9MAX's Avatar
Default Wiring up resistor box...?
Ok so just getting done installing my turbosetup.
Not I bought this used and it had a resistor pack already wiring in. During the un-install on teh other end the wires kinda got messed up....
Here's some pics.... There's one red one tha tgoes to ignition switched 12v..
All teh rest are black.... Does i tmatter where they get wired in???
Old Nov 26, 2008 | 04:39 PM
Kirpich's Avatar
I never installed one, but one wire must be going to power, one to ground, and the rest are to injector's grounds, I believe.
Old Nov 26, 2008 | 04:48 PM
EK9MAX's Avatar
Look at the bottom picture. There's 4 black wires that clearly go tot eh yellow/black injector wires off the harness....
But the last black wire with black electrical tape on it.... does that go to ground?
Old Nov 26, 2008 | 06:57 PM
Kirpich's Avatar
Try that. Worst case scenario, a fuse blows. But try to find some installation instructions, either from a guy who sold you this box, or online.
Old Nov 26, 2008 | 07:48 PM
EK9MAX's Avatar
ya i tried asking him.....
he doesn't know....
But really i can tell which wires go to teh harness pretty easily. Just the one black wire that is left... must go to ground.
Old Nov 28, 2008 | 10:27 AM
Ultimate Racing's Avatar
A resistor pack goes inline with the power feeds to your injectors.
The red wire is most likely the switched 12V that will be running through the resistor pack and feeding the injectors. All the blacks should be the 12V outputs to each injector. It shouldn't matter which black wire goes to which injector. Injector grounds should remain untouched from factory.
Hope this helps.
Darryl
Old Nov 28, 2008 | 12:51 PM
AndyFloyd's Avatar
yea, one power wire and the others can be wired into any of the injectors in any order.
Old Nov 28, 2008 | 02:40 PM
Kirpich's Avatar
Ok, now I'm a bit confused. Shouldn't there be 8 wires then for injectors? 4 leads in, 4 leads out? and then 1 power, and 1 ground on top?
Or do you Tee into the injecor pulse wire with each lead?
Old Nov 28, 2008 | 03:24 PM
jcoosi's Avatar
Here is a link that has some wiring info
http://www.honda-tech.com/showthread.php?t...w+resistor+wire
1SlowSi
Sep 21, 2014 04:00 PM
nnguyen90
Oct 5, 2010 12:20 PM
macprotege5
Mar 7, 2007 06:22 AM
NFRs2000NYC
Feb 11, 2004 07:54 PM
