Yet another DIFF
Old Sep 6, 2011 | 08:15 AM
jpetch05's Avatar
Also what is my success rate with buying a used stock diff and having puddymod build it ? Strength wise ? Pros and cons?
Old Sep 6, 2011 | 08:44 AM
DFWs2k's Avatar
None have ever been broken.
Sent using free Tapatalk - Android ftw
Old Sep 6, 2011 | 09:26 AM
jpetch05's Avatar
Okay well I'll check it out and let you guys know. I haven't been home or had the time to drain the oil. I probably will today when I'm home. But I'm almost positive it's my diff
Old Sep 6, 2011 | 09:29 AM
fmfkid250's Avatar
Whenever I break mine I think i am going with a "bolt in" 9"...
Old Sep 6, 2011 | 01:00 PM
jpetch05's Avatar
Metal chips in diff fluid. Bout 9 of em. Size of small pebbles
Old Sep 6, 2011 | 01:22 PM
JoeyBalls's Avatar
Originally Posted by AusS2000
Yeah, if you can't afford a 20K transmission you shouldn't have turbo'd the car! Hang on, I can't afford a $3K diff either!
I was thinking the same thing, lol
Old Sep 6, 2011 | 03:41 PM
jpetch05's Avatar
I'm going with the 3.9 ford and aluminum shafts plus
Old Sep 7, 2011 | 11:07 AM
BrockB's Avatar
the cheapest solution for your power level only being in the 400s that should NOT break again is a puddymod built differential.
Anything else will be more expensive (besides simply replacing your diff with an oem one) and the 8.8's and stuff like that i think are a little overkill for the power you're running.
puddymod should be your answer
Old Sep 7, 2011 | 01:25 PM
wadzii's Avatar
Banned
A fully done up puddy diff will run you more than $3000.. may as well do the ford 8.8, have cheap easy to find replacement parts, a better driveshaft and better axles.
Old Sep 7, 2011 | 01:39 PM
Angerman's Avatar
Originally Posted by s2000Junky
Stock ap2 diff W/reinforced carrier bearing end caps. Cheapest solution and stronger then stock, being that it the weak link of the stock diff. Stock end caps flex under load, and overtime throw the ring/pinion out of alignment and one day crunchy time happens. How much trq you have and how hard you put it to the diff will dictate how long before this happens.
If you don't do anything, at least get an ap2 diff to replace since it has thicker end caps over the ap1.
If money is a problem then +1 on this idea.
If not, get the Puddymod stage 2 diff or Ford 8.8
