Your Status...
Old Oct 27, 2010 | 01:25 PM
Suzuka_Joe's Avatar
Stock f20c greddy kit at 72k made 280@11psi
74k Mase kit 5857 made 422/261@13psi
78k now with zero issues
Old Oct 27, 2010 | 01:36 PM
Soul Coughing's Avatar
1st
My first engine was the original to this chassis. It had 40k miles and was an '01 with the older oil jets. I ran a stock comptech supercharger with AC and ran it lean over one night and scored a cylinder.
2nd
I put in a used bottom end and reused my old head, running an AEM EMS, 3mm headgasket and a 3inch pulley, making 14psi at 9500 rpms. This motor lasted 3k miles as the people putting it together, and myself missed a sunken retainer on the intake side, which resulted in a dropped valve, grenading the bottom end and head. This retainer was more than likely damaged from an earlier owner, as i had never miss shifted a gear or over revved the car. The block and head Make great paper weights, boat anchors or yard accoutrements.
3rd
The 3rd motor was a f22, and had been turboed for 15k before i bought it. This motor now has about 65k miles of boost on it, revving to at least 8500 the entire time. It has made 380whp, 420whp, 475whp on 3 seperate 3mm headgaskets and between 300-365ft/lbs of torque. I have driven the piss out of this motor and the motor still has compression within 3% in each cylinders. I recently went back to stock compression and am making 448whp and 302ft/lbs of torque and the motor still feels strong and idles normally. I daily drove this car for 3 years with this motor, including 450 mile trips to see a girlfriend and 250 mile runs up to Boston to see college buddies. The motor never left me stranded, only with a two step launch at island drag way and a grenading rear end did i need i need a tow. The former being a broken axle, and the latter being 30 yards from my house.
Old Oct 27, 2010 | 02:52 PM
elmisterioso666's Avatar
elmisterioso666
stock 01 ap1 140k
5k of boost
3mm gasket
630whp on 93oct nd meth
alot of abuse!!!![media]http://www.youtube.com/watch?v=kT8GMEZFH7Y [/media][media]http://www.youtube.com/watch?v=OtwlCrzPVAQ [/media][media]http://www.youtube.com/watch?v=pM2huKw_WHo [/media]
10 sec civic[media]http://www.youtube.com/watch?v=cp1BCEDbqaw [/media][media]http://www.youtube.com/watch?v=3OwhmoqBTLs [/media]
Old Oct 27, 2010 | 04:07 PM
sIIooo's Avatar
Stock f20c turbo 320hp over 100k miles last 8k boosted. Rings went bad and screwed the block. I now have an F22 with a supertech built head that I just got running again last night so hopefully this one will last.
Old Oct 28, 2010 | 02:52 AM
NFRs2000NYC's Avatar
Not a crazy build, but boosted nonetheless....
2003, Greddy Kit, 300hp/220tq. Stock motor, test pipe, HKS exhaust. Runs flawlessly in any weather. Car has 42K on it, last 4K (one year) being boosted.
Old Oct 28, 2010 | 05:17 AM
siadam's Avatar
Originally Posted by DFWs2k,Oct 27 2010, 12:38 PM
stock f20c w newer oil jet bolts, 450 whp/288wtq, 93 octane, inlinepro sidewinder, 15 psi, 9500 rpm rev limit, ~80k miles on engine when turbo installed, ~94k now
Why did you upgrade/replace your oil jet bolts?
Old Oct 28, 2010 | 05:18 AM
siadam's Avatar
Originally Posted by TurboR,Oct 27 2010, 12:56 PM
Laskey built short block, stock head, 2.2L, Mase's kit 720whp/528tq @ 32psi E85, stock diff and tranny, 7k races every weekend. No issues.
Why did you rebuild your block initially?
Old Oct 28, 2010 | 05:26 AM
PsykotiK's Avatar
original engine was scored on #4 cylinder while participating in a group drive while i was N/A
low oil + older oil jet bolts + high speed driving + high speed curves = expensive way to learn to check oil level everyday
-dfws2k
Old Oct 28, 2010 | 05:35 AM
siadam's Avatar
-dfws2k
Thanks just clarifying.
Old Oct 28, 2010 | 05:37 AM
siadam's Avatar
Thanks to everyone who has contributed thus far.
I know sometimes we don't like to admit our failures, but this helps everyone in the long run I think.
I'd also like to post up some other setups, some high whp setups if anyone can remember them, or knows the posts.
I know Kuju...and Fullblown had some solid numbers, Rob!, and Andy for a while.
Maybe someone that knows them, can chime in.
