Zex Smart Nitrous Kit.
Old Mar 11, 2008 | 01:30 PM
afwfjustin's Avatar
Originally Posted by S2KVITO,Mar 9 2008, 05:16 PM
Exactly I try to tell that to all the rustang ppl around my town when they brag about there NAWZ systems.
Is that just an excuse you give them after they beat you?
Nitrous is perfectly acceptable in my opinion. And peak hp for peak hp, nitrous is faster than turbo.
Old Mar 11, 2008 | 04:11 PM
s.hasan546's Avatar
but then they blow by you so it doesn't matter... nitrous is still making power....
power is power.... if its geting you done the quarter quicker its the same thing
Old Mar 11, 2008 | 05:06 PM
one_slows2k's Avatar
Originally Posted by f23power,Mar 9 2008, 11:52 AM
"bottles are for babies..real men get blown"
=P
-a
So where does that leave n/a? and please, could you use another quote, that one is REAAAALLY OLD. lol Only people who really put down nitrous are the ones who have no clue on how they work, or pretend they do. If done right and not abused, nitrous is perfectly fine.
I installed a zex kit before on an s2000 but i forgot the color though. But if you search s2ki you will find your answer, this is where I found it. good luck man.
Old Mar 11, 2008 | 08:07 PM
FTW.inc's Avatar
a friend of mine also suggested that i run a larger fuel jet (one size large; the fuel jet called for with a 65 or 75 shot) along with the 55 shot of nitrous. Anybody else heard of that? Any opinions or thoughts on that?
Old Mar 12, 2008 | 09:03 AM
check your plugs on each run and compare the 2. I wouldnt use the 75 fuel pill on the 55 nitrous pill.. u can try 55 and 65 and see if it makes a difference.
PS the s2k i installed the nitrous on ran 65 fuel and nitrous pill. Ran perfectly fine
Old Mar 12, 2008 | 10:08 AM
secrets2k's Avatar
i had an 80 shot on mine it work great best time i got was a 13.1 at 105.9 but that was with half a bottle def could have seen 12.8 but i had a .046 nitrous jet and a .027 fuel jet 2 sets higher on the fuel...would reccomend 1 step colder plugs and your going to have to change your oil more often due to gas getting into the oil
Old Mar 12, 2008 | 09:46 PM
FTW.inc's Avatar
.046 nitrous is a 100 shot, and .026 is the fuel jet recommended for it.
http://zex.com/ and then search "jet" and click on "jet chart" ...that's if you're running zex, i dont know if all jets regardless of the company are the same.
Old Mar 13, 2008 | 05:49 AM
secrets2k's Avatar
hmmm thats perdictied hp...actually whp is 81.5....so i just call it an 80 shot
Old Mar 14, 2008 | 06:56 AM
FTW.inc's Avatar
Originally Posted by AusS2000,Mar 9 2008, 04:27 PM
White? Dunno.
But it is the wire whose value changes with the throttle position so it ain't hard to find.
You'd use a vampire tap connector for quick and easy connection.
But looking at your question (And if any of my answer still leaves you confused) STEP AWAY FOR THE ENGINE and pay someone who knows what they are doing install it.
if i disconnected the plug that the wire is on and used a VOM to check voltage drop or change from the TPS to the prongs in the plug it would work right?
Old Mar 14, 2008 | 02:36 PM
AusS2000's Avatar
You will need the plug connected to see the variation.
