Zex Smart Nitrous Kit.
I was reading on the Zex website and one of the instructions is to "Run the white wire from the Nitrous Management Unit to the output voltage lead from the throttle position sensor." It says that the wire from the TPS should be white. Is it white in the S2000, and how would you hook up to that?
Originally Posted by f23power,Mar 9 2008, 11:52 AM
"bottles are for babies..real men get blown"
=P
-a
=P
-a
But it is the wire whose value changes with the throttle position so it ain't hard to find.
You'd use a vampire tap connector for quick and easy connection.
But looking at your question (And if any of my answer still leaves you confused) STEP AWAY FOR THE ENGINE and pay someone who knows what they are doing install it.
Hey, I have a zex system in my RX-8. The color of the wire will vary by car, when they say white, they are referring to the wire on the management unit. The management unit has 3 wires coming from it: the power (red: obviously taps for power), ground (black: ground for the system), and then the throttle position wire (white: taps to detect WOT to activate system). I'm not sure where this wire is on the s2k unfortunately but hope this might have helped clear it up? I've been using the same kit for a few months and very satisfied btw. Not sure exactly the results you get from the s2k but should be nice.
