Clear Yellow and White
Old Feb 27, 2001 | 08:23 PM
pnty drpr's Avatar
The results of the many hours of work.
The clear lights look much better.
Old Feb 27, 2001 | 08:36 PM
Sfen's Avatar
Cool, How much are the clear light and where to get them?
The Captain's Avatar
Looks good. What does it involve to do this?
Kirk
Old Feb 27, 2001 | 11:06 PM
nvmys2k's Avatar
Seems like photopoint.com is down at the moment. Can't see anything...
Old Feb 28, 2001 | 07:24 AM
S2K-F8's Avatar
Kirk
Kirk,
This involves removing the front bumper, removing the brackets below the headlights, then removing the headlight assembly (several hidden bolts holding them in). The seal between the headlight lens and housing is then heated with a heat gun and slowly preyed apart (this step is very time consuming). Once the headlight assembly is seperated, the internal amber lens is removed.
Then you just repeat the process in reverse to put everything back together. We also put a layer of silicon sealent around the seam of the headlight assembly just to be on the safe side.
It took about 7hrs. to complete.
Old Feb 28, 2001 | 07:28 AM
Kirk
Kirk,
Thanks for the info. I'm not sure I would feel confident enough to do that without breaking something but it does look really good. Congrats on a great job!
Kirk
Old Feb 28, 2001 | 08:14 AM
S2K-F8's Avatar
Sfen,
These are the factory headlights that have been taken apart to remove the inner amber lens.
Old Feb 28, 2001 | 12:29 PM
S2kRob's Avatar
I have to say that these lights look better than the factory clears because of the "crystal" like nature of them.
Those S2k's are super sweet, BTW.
Is there a full gallery to check out?
Old Feb 28, 2001 | 01:07 PM
s2ko's Avatar
Those look sweet. I may just try and do that to my silver.
Old Feb 28, 2001 | 02:04 PM
pnty drpr's Avatar
S2kRob,
I agree with you. I like the inside of the housing much better than a clear plastic lense. The polished lips of the rims and the "crystal" inner housing on the lights look great.
I don't have that many pics yet, but will take many, many this weekend.
You can look at whatever I have at:
http://albums.photopoint.com/j/AlbumList?u=1393058
S2K is old pics
S2K-2 is the new ones (all at night, so they are not so clear)
Scott is a folder with a couple of shots of S2K-F8's car.
