Sever Camber and toe in
Old May 24, 2001 | 07:27 PM
S2000 Owner's Avatar
A lesson in autocross. (Big course --- Monaco)
Had to post this!!
[Edited by S2000 Owner on 05-25-2001 at 03:11 AM]
Old May 24, 2001 | 11:46 PM
nvmys2k's Avatar
So what would be the advantages of having the camber and toe in that far?
Old May 25, 2001 | 12:40 AM
Takashi KazuMori's Avatar
Complete flatness of all your tyres being on the tarmac, while I don't like that one much. I prefer Jordan's or BAR's cars. I'm a Honda supporter.
Old May 25, 2001 | 02:09 AM
Just ask some of our Autocross guys. They reset the S2000 to maximum negative camber so the the tire on the outside of the car on a turn (right or left), has maximum tire patch to the pavement.
If you think about it, you can see that you need maximum mechanical grip for a corner, but not for a straight! The maximum forces are on the corners, so after a run; they take tire temperatures to see if it's even on the outside middle and inside of the tire. If it's hotter on the inside, then you add positive camber; if it's hotter on the outside then you add negative camber. If it's hotter in the center, then lower the air pressure; and if it's hotter on the edges, then add air pressure.
Old May 28, 2001 | 11:45 PM
nvmys2k's Avatar
S2000 Owner, that makes sense...Thanx.
Old May 29, 2001 | 08:05 AM
S2K Fan's Avatar
I particularly like the photo
Old May 29, 2001 | 01:42 PM
Chiman's Avatar
How can we easily add/minus camber to our car??
Coil-over suspension? Camber Kid??
John
theS2K
Jul 12, 2015 11:05 PM
Popa
Oct 29, 2011 09:05 AM
owenxguo
Sep 21, 2008 11:39 AM
slipper
Aug 25, 2007 05:57 AM
jguerdat
Apr 30, 2001 11:02 AM
