S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
2004 Radio door problem
Old Feb 12, 2004 | 06:18 PM
LordMagnet's Avatar
Default 2004 Radio door problem
I installed the 2004 radio door, but when I press the door it won't go down, it'll just sit there. But when I move it about 25% down more it'll slowly move all the way down. Any tips? Thanks.
Old Feb 12, 2004 | 06:23 PM
naynay's Avatar
The spring on the back isn't set right, what brings it down the rest of the way once past the "25%" mark is just gravity, simply the weight of the door forcing it down. I also had the same problem. If you can pull out a friends door housing (not door) and see how the spring is set this will help!
Old Feb 12, 2004 | 06:27 PM
swtazn97's Avatar
Old Feb 12, 2004 | 06:29 PM
LordMagnet's Avatar
Thanks for the help. Now... i don't have any friends with s2000's, can anyone post a picture? Thanks!
Old Feb 12, 2004 | 06:31 PM
naynay's Avatar
I will see if I can get some for you (no promises)!!
Old Feb 13, 2004 | 10:47 PM
LordMagnet's Avatar
TTT
Can anyone help me out with a pic? Thanks.
Old Feb 13, 2004 | 10:55 PM
JL9000's Avatar
And this didn't happen with your previous radio door?
It's pretty normal for the radio door to get stuck when cold.
Old Feb 14, 2004 | 12:04 AM
PortugueseS2K's Avatar
Im still tryin to figure out how the hell to take those pins out! Its such a narrow space
Old Feb 14, 2004 | 01:57 AM
swtazn97's Avatar
a metal coat hanger bro. straighten it out, and snip the end with a good pair of pliers. Make sure the tip of it is smooth so it glides the pins out from the inside out.
Old Feb 14, 2004 | 05:52 AM
Ajjra's Avatar
Paperclip worked great for me...
