S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
belt buckle
Old Feb 27, 2010 | 08:32 AM
KchaoS2K's Avatar
Default belt buckle
how are people mounting the belt buckle with racing seats or are u switching it out to a longer one? Talking about the female end where you clip in..??
Old Feb 28, 2010 | 03:19 AM
Globe182jp's Avatar
A harness is the best way but without a Roll bar it puts people off. It all depends on how wide the seat it.. but most just leave it right under the lip of the side of the seat. it can be a pain to unhook.
Jake
Old Mar 16, 2010 | 05:43 PM
jbird's Avatar
A harness is only a good idea when used in conjunction with a proper head/neck restraint. In case of accident you will be strapped in too tight and the whiplash will be severe.
I saw in the aftermarket seat thread there was a guy who recommended using a plate to extend the female buckle up pass the bolster
Old Mar 19, 2010 | 04:41 PM
chuhsi's Avatar
I'm also looking for a seat belt receptacle extension solution
Old Mar 21, 2010 | 09:38 AM
yose's Avatar
i have 2 factory seat belt buckles
Old Apr 12, 2010 | 05:49 AM
mathiss2k's Avatar
my factory female seat belt buckels had bends in them to get around the factory seat and up to you where they were supposed to be.. i just put the bends on a vice and straightend them out. they extended about 2 inches. (almost perfect for bride low-max)
Old May 7, 2010 | 07:21 AM
chuhsi's Avatar
Can you please post a picture of this? Sounds like the solution I need.
Old May 11, 2010 | 12:10 PM
JHooby's Avatar
i went to Ace hardware and made myself an extension.
it's quite easy !
Old May 11, 2010 | 12:40 PM
chuhsi's Avatar
it's quite easy !
Can you walk me through how you did this? pictures and part numbers? thanks
Mocky
Apr 13, 2014 11:29 PM
syck
Dec 27, 2011 03:27 PM
Matt_in_VA
Jan 2, 2007 06:53 PM
cthree
S2000 Service Bulletins (TSB)
Mar 12, 2005 10:03 AM
