S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Big guy small problem.
Old Jul 26, 2010 | 09:51 PM
Buriantsu's Avatar
Thumbs down Big guy small problem.
Hello!
I want a S2000 and there is a problem I'm 6'4 and about 275-280lbs. True story I can lose the weight but I can't do much about my height. My question is there anyone that has gone through this problem and can help me by telling me if I need to buy seat rails or do I modify the stock rails so I can sit much lower, I know buy me getting an aftermarket wheel helps but i need a bit more than just a steering wheel. I would think that I can do something with the stock rails to just plant the seat lower and probably removing some panels from the back of the seat so it can go further back?
If anyone has an idea and can help me out that would be great.
THANKS
-Bryant
Old Jul 27, 2010 | 08:43 PM
YEGGT's Avatar
I'm 6'4".. buying the BYS rails shortly (or custom modding the OEM rails) to drop the sest 2cm.
I'm not 280 though.. more like 210.
Old Jul 27, 2010 | 08:57 PM
Honda007's Avatar
6'5"-6'6" roughly 215 lbs. Im fine with my crappy random seats(replaced by previous owner, I guess due to originals being stolen) I actually have more legroom with the stock seats, but the stock holsters do hug closely. You should be fine on leg room at least. You can take some of the support material out of the bottom of the stock seats to help you sit lower in the car, there are a couple DIY's on helping taller individuals fit in the S.
EDIT: BTW ap2 tend to have a tad more leg room, 06+ also have a tiny more room.
Old Jul 31, 2010 | 09:44 AM
SRap1's Avatar
I removed and rewelded the stock seat brackets as low as i could make them, and bought a 280mm steering wheel. The wheel helps alot.. but it blocks the view of the upper rpms. I too want to know what aftermarket seat sits the lowest and has as much bolster room as stock.
Old Aug 5, 2010 | 04:40 AM
dammitjim's Avatar
You can lower the seat pan. There is a DIY for it and it's not that difficult.
MartinK
Aug 24, 2016 11:23 AM
cheddaboy
Nov 27, 2014 06:19 PM
aarons2k2002
Feb 11, 2008 12:40 PM
chong2k
Dec 18, 2006 04:50 PM
jspecracer
Dec 10, 2004 01:25 PM
