S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Deform lines on dashboard
Old Sep 17, 2008 | 09:23 PM
tntrac's Avatar
Default Deform lines on dashboard
Guys,
Just curious if others have lines on their dashboard. Right now I can see them at certain angles and barely noticeable when I put my fingers on them (no major lump yet)
Car has been only 10 months old. I have not seen these lines on my previous car.
Tnt
Old Sep 18, 2008 | 05:09 AM
shamoo's Avatar
I haven't seen it on my 07, and I do keep it parked outside on my driveway all the time (unfortunately ) I also don't have the year round sun that California has, so I don't know.
But.....back to the dealer I would go. You should still have a warranty....unless you drive as much as I do. My 36K one has been over about 800 miles ago.
Old Sep 18, 2008 | 07:42 AM
tntrac's Avatar
Car only has 9k miles and I do have a garage. I am not sure at this point is it worth having the dealer took her apart. They might do more damage than fix the problem .
Tnt
Old Sep 18, 2008 | 08:11 AM
roflitzjinno's Avatar
well just have them look at it? they wont take anything apart without determining what the problem is. a doctor isnt going to operate without diagnosing the problem first. same concept.
Old Sep 18, 2008 | 09:14 AM
tekstar's Avatar
this is a common issue... if you do a search for "bubbling dash" you'll find that many owners have had success taking their cars in to have the dash replaced under warranty
Old Sep 18, 2008 | 10:09 AM
shamoo's Avatar
I'm also aware of the "bubbling" dash, but that affects the older AP1s only. I don't know of any newer AP2s that have this problem. The dash material is actually different on the newer models.
Old Sep 18, 2008 | 10:18 AM
tekstar's Avatar
wrong, there have been reports of ap2 owners with the same issue. what material are the newer dashes made of? i was under the impression they were all vinyl...
https://www.s2ki.com/forums/index.php?showt...&#entry11284000
https://www.s2ki.com/forums/index.ph...ic=431768&st=0
Old Sep 18, 2008 | 12:57 PM
shamoo's Avatar
I stand corrected then, but I thought they were AP1s only. Sorry about that. I did hear somewhere on here that the newer AP2 dashes were slightly different, although I cannot confirm. I had an 01 that was stolen pretty quickly, then several years later got my 07. Don't remember my 01 too much.
Old Sep 18, 2008 | 04:53 PM
tntrac's Avatar
Took a drive to Norm Reeves in Huntington Beach (some here recommended).
The manager said he has no problem replacing (doesn't sound so thrill) the dash but highly recommended that I don't do it cause it will not be the same, ie scratches, rattles. He said it is not that visible unless "you look for it" and recommended that I do it when it is more visible.
I am kind of undecided if I should let the dealer tear her apart. I recently had my 350z roadster's top replaced by the dealer and it took them mutiple times to do it right.
I guess I will live with it until my warranty is close to expiring.
Tnt
Old Sep 19, 2008 | 04:15 AM
oOweEe's Avatar
Are you wearing a bra??
