S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Footwell LED Lights
Old Jun 2, 2011 | 08:34 AM
Eric220's Avatar
Default Footwell LED Lights
Hey guys,
I recently installed some footwell LED lights in my S. I wired them to the door latch so every time the doors are open the lights come on. The only problem is that ever since I wired these, my Compustar alarm trips ever so often (voltage/current from led related..?) I was wondering if there is another spot I could try wiring so that they still turn on when the doors open. How have you guys wired yours??
Thanks!
Old Jun 2, 2011 | 05:57 PM
icantbeseen1's Avatar
you could run it up to the map lights if im not mistaken
Old Jun 4, 2011 | 07:04 PM
DvS-'s Avatar
i wired mine to the map lights. So when the doors open or when i turn the map lights on the footwell lights turn on.
Old Jun 7, 2011 | 08:26 AM
Eric220's Avatar
Sounds good, what's the easiest way to tap into the map lights? Do I really have to run wires all the way up to the windshield?
Old Nov 24, 2011 | 03:16 PM
twinpnoy84's Avatar
I would like to do this mod as well. Can anyone do a tutorial? Thanks
Old Nov 24, 2011 | 05:41 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
+1
Old Nov 29, 2011 | 03:46 AM
CitadelBlue's Avatar
Although I used regular light socket that takes a 12 volt light bulb (these were readily available at car parts stores/Wal-Marts/etc)I ran a separate wire to the fuse panel, added a "add a mini-fuse" then tapped into each door ground button. When either door opens, the footwell lights come one ......
lxhlms11
Mar 25, 2012 07:44 PM
Joseito92
Feb 15, 2012 02:36 PM
NsaneR3vs
13
Nov 14, 2011 11:10 AM
darkfx
Mar 31, 2006 06:56 PM
tom717
Jul 13, 2004 02:22 PM
