S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
help with nrg quick release install?
Old Sep 20, 2012 | 07:46 AM
benw.17's Avatar
Default help with nrg quick release install?
Hello I just order an nrg quick release hub and personal steering wheel and was wondering if anyone could show me a good DIY write up or tell me how to install it.
Old Sep 20, 2012 | 02:32 PM
03suzuka...s2000's Avatar
Looks to me like your missing the hub. You only have quick release and stearing wheel. The little part of the quick release that pops out when.you pull back on the quick release should,bolt to another peice called the hub.
Old Sep 20, 2012 | 08:35 PM
benw.17's Avatar
Ok I'll order that. But can I install these and not have the airbag light come on?
Old Sep 21, 2012 | 01:26 AM
Just thos parts cant be installed without the hub. But do your research I beleive there is one hub with electronics in it to fool the airbag light. Otherwise take out the cluster and put some electrical tape between the bulb and where you see the airbag light up on the cluster. Thats the trick on the old civics I use to have these on. But if you find that hub that.bb takes care of it
Old Sep 22, 2012 | 08:37 PM
KLASMID's Avatar
Newer nrg hubs come with a relay to not trip the light. If your light does come on once you are done follow the steps in the link to reset it.
http://www.honda-acura.net/forums/do...srs-reset.html
Acethriller
Mar 17, 2016 10:21 AM
Munnerlyn
Nov 19, 2013 04:05 PM
FTW.inc
Jun 4, 2010 02:41 PM
regmilla
Sep 29, 2005 05:27 PM
