Idenification Seat
Idenification Seat
I got my seats stolen and now I have just bought some used seats with no info on what year seats theses s2000 seats are. The plastic back piece on the head rest is sliver and its a honey comb. I tried to line up the rail on the passenger side, no go. I tried the driver side, no go. The on side of seat rail slide back and forth when you raise the track to slide the seat. Should that do that? What do I need to do to make it fit? Swap rails? How hard is the work to swap? Just bolt and unbolt?? Thanks in advance.
I tried to search but found nothing related to this issue.
ok i just did the swap on my cr seats with ap1 rails. You dont need to change rails on the driver side since for all years they are interchangeable but the passenger side had a driver rail that was different to accomodate the srs seat sensor. I though it was going to be hard but you just had to unbolt about 6 bolts all around and the hardest ones was one single bolt that in order to get to it you needed to remove two hog rings on the upper part of the seat and then you can fold the skin on the seat back enough to get it with your rachet. Just do the process backwards with the ap1 rails and it should just bolts right on to your car like stock. If you have the honey comb seats it should fit on your ap1 since all seats from 00-05 fit unless you bought some stolen s2k seats with civic rails or integra rails.
My seats are at my parents and so is my car. I had my brother measure the rail holes and compare it to the floor holes on my car. Not a match!!!! WTF!!! I'm fuccking piss!! All seats in the clasified were hard to get a hold of so i went local and ended up in a set back. Does anyone know how I could go about fixing this issue? Were could I buy ap1 rails? These were the measurements...
Holes in car are 18.5 (outside) & 16.5 (in).
Seats rails are 14.5 (outside) & 15.5 (in).
Can someone take a picture of their seats bracket rails for me pls??? I really want to know how they Gould look like an I can't find anything on seats in google.. Thanks in advance.
